LancsRick
Right, whetstones. They're wet, they sharpen, and they conveniently get identified by their grit so that you work from low to high and end up with a mirror, right? Nope...
I have a set of 3 whetstones from Rutlands (600,1000,3000), and another 8000 grit from Amazon which seems to get good reviews all over the place. From the 3000, I can start getting a mirror finish on my edges, and after a bit of use the stone surface feels extremely smooth. For the 8000 though, it seems to cut faster and doesn't get surface clogged.
Which is the oddball in this scenario? Have I got a 3000 that clogs too quickly, therefore smoothing out and allowing a higher effective grit? Or have I got an 8000 that is actually coarser and should perform differently?
I realise I could spend £80 per stone and get some excellent ones, however, this is a temporary solution until I pick up a good rotary wet grind system like Tormek, so I just want to do something sensible but effective in the meantime.
Cheers.
Cheers.
