heimlaga
As I am collecting parts to rebuild my Jonsered FM-C the question of RPM arose.
Jonsered FM-C was primarily designed to be line shaft powered. One could get an electric motor with a very solid motor mount as an extra. Mine has that factory made motor mount but it lost the original motor long ago. The current motor is a 4kW 2800RPM VEM made in East Germany. With the home made wooden pulley currently fitted the spindle speed should be somewhere around 8000 RPM though I could not get an exact measurement of the spindle pulley in the darkness of the barn.
I am pondering over if I could make the motor pulley easy to shift so I could get two different speeds with two different pulleys.
Which speeds should that be?
