TrimTheKing
Hey chaps
Need some help please. My underground gas tank keeps filling with water (the chamber it's in, not the actual tank) and submerging the upso/opso switch, which if not kep under control eventually kills the diaphragm in the switch dropping my gas PSI to levels where the oven won't fire up.
Shell came out and replaced the upso/opso 2 weeks ago but told me I need to keep the chamber clear or they will start charging me to change it next time. Typically it is pi$$ing it down and if I get out there and clear it by hand in the morning it is filling up again by evening and I just can;t spend all my time doing this with a jug.
I need some kind of pump, preferably automatic but manual is fine so long as it's reasonably quick. Cheap as possible but to do the job. When I open the manhole the seal is fine so I'm sure it's ground water filling the chamber and I can only get it down so far with a jug so something with a pipe/hose to get down the side of the tank and get some of the gound water out would be ideal.
I am currently scouring MachineMart but there are over 400 pumps come up with a search of 'small pump', and I haven't got a clue what I shouldbe looking for.
Any ideas out there???
Help!!!
Help!!!
