Drudgeon":fsyyrzod said:
A friend of mine is purchasing American Black Walnut worktops for his kitchen, but he would like to darken down to try to take out the variance of colour in the strips... Dan
It can be done, but it's a fiddly job and I wouldn't attempt either of the following methods for a kitchen worktop.
The problem is that simply dying the wood with a dark dye will change the colour of everything by the same amount. The dark bits will get darker, and the pale bits will too ... but the differences between the sapwood and the heartwood will still show through.
The first solution is localised sap staining undertaken with dye applied to the sapwood building up the colour through varying the dye colour proportions and applying the mix with a spray gun, usually an airbrush type gun. It's fiddly and time consuming. After that you apply a polish.
The second solution is to bleach the wood all to white and then colour it up to whatever you want, finishing with a polish.
As I said at the beginning neither solution is really a workable and realistic option in a kitchen worktop in my experience because of the abuse it's going to experience in life, no matter how carefully the owner of the worktop says their family will be. Inevitably someone will cause damage at some point in the future, and this usually leads to the damaged area being the beginning of extensive deterioration in the surface of the worktop. This then leads to things like stripping back or sanding, and then the process of refinishing using similar methods to the original has to be considered. It's much easier if the top's finished natural in the first place, and then simply restored as and when needed later: most people use some sort of easy to apply oil finish. The reality is that if your friend wanted uniformity of colour then purchasing a walnut worktop probably wasn't the ideal choice. Most people buy this kind of thing because they relish the variations in grain pattern, colour and texture and expect to live with it, repairs and all, not the opposite. Slainte.
