Lark
what I am doing is cutting 2 sides and 2 tops joined by 45/ "front and back will be mdf painted so not a prob"
i have a Bosch gts10 table saw with 80 teeth blade
"straight cut"ripping cut not too bad... cross cut bad on the top side and not to bad on the bottom side... this is before I cross cut 45 degrees "test to see how blade would cut"
i don't think the saw blade is much good or are most blade like this...
i will get around to testing a 45 degree cut soon but thought would ask first.....
i do have a festool plunge saw and track.... cuts are good on it.... but with out a MFT its harder to get all cuts same like with a table saw... also when the wood is not so big.. tops 250mm x 230mm
