Giff
Has anyone any experience with Bag press or Air press. PVC bags, Polyureythene bags or Vinyl bags ? Mainly for forming and veneering flat panels.
Giff":25a3cwgl said:1.BagPress or AirPress ? and which bags. There seem to be vinyl, PVC and polyurethane.
2.Looking at the "build thread", which is really useful, it seems that the prices are a lot more than in the post (it was a few years ago).
3.Also does the pump have to be on until the adhesive has cured.
4.Are they noisy.
5.Would the workshop have to be at a certain temperature.
With a hydraulic press the pressure is applied in one plane, i.e., vertically. With a bag press, or a vac bag there's stretch in the bag. As the pressure is applied there's a tendency for the bag to suck down unevenly, often with wrinkles, and for the bag to drag sideways a bit as it's sucked into place. This can open up join lines or cause wrinkles as it drags the veneer one way or another. A board or boards over the top of the veneer reduce the chance of this sideways movement, and thus reduces the number of failures ... and I've seen plenty of failures, especially when inexperienced woodworkers go at the job and ignore my suggestion/instruction to stick a few boards over the top.Steve Maskery":3h262jab said:Richard
I've not come across the pyramid thingy before. Can you explain please how it evens out the pressure? I would have thought that 14 PSI (or whatever approximation the press achieves) will be 14PSI over the whole area. Clearly you find it beneficial, but I don't understand what it does.
Can you explain further please?
Giff":3cgyyxez said:Custard could you explain what this means... "Remember that the pressure in any vac system only just meets the minimum requirements for most adhesives" I haven't come across this before. Thanks Geoff
