urgent - finish to apply over paint?
miles_hot
27 Jul 2008
Swindon
Hi all
I have just done a little project with the children where they have sponged washable paint (which will apparently not come out from porous surfaces like wood which is good) over an unfinished wooden bowl. I want to seal in the paint and give a slightly smoother finish to it. I was expecting to be able to use something like Chestnut Hard Wax oil however reading the tin it says to only use on unsealed wood.
Can I still use the Oil or will it get annoyed with the water based paint finish? If not what can I use?
Many thanks
Miles
PS this is urgent as I need an answer before we go back into the garage tomorrow to finish off the present for their Mother :) Due to the urgency I'm cross posting to the turning, general and finishing boards so I apologise in advance :)
yes you can apply wax over water based paint. But it has risk to the wax to resolve some of your water based paint.
It is better if you apply a thin coat of clear coat on your paint, You can apply a thin shellac, lacquer or varnish to seal and protect your paint.
Good luck
wisno
