Ungluing a drawer.
Jacob
New Luddism. Wake up and resist.
7 Jul 2010
Derbyshire
Got a trad drawer to mend all heavily glued together with trad bone glue.
Will try to separate joints with hot air gun, or iron, and damp cloth.
Just wondered if anybody had any useful suggestions which might make it easier.
More of a prob than some as it's a fairly hefty drawer with thick sides and large glued area surfaces
Some hints here already disassembling a hardened PVA glue-up. I guess if it works for PVA it should be easier with bone glue.
Sometimes a sharp blow with a mallet will break the brittle glueline with hide glue, but this is obviously an approach not without risk!
Hide is much more susceptible to moisture and heat rather than dry heat, in fact it is very popular as a glue in luthiery for this reason - it can withstand dry heat better than almost any other glue, but will release quite easily when water is added to the equation.
Edit
**oops, didn't read carefully enough. Is bone glue different from hide glue?**
Leave it in front of a halogen heater, it will heat up the material over a few hours without burning and you can then tap it apart.
A luthier I know once told me he uses alcohol when removing the top or back of a violin.
I've never tried it though.
De-natured alcohol works very well on old thin hide or fish glue joints and is (as above from djz) a traditional way with violin, cello etc tops. Works well (done it several times under instruction in Italy). Usual approach was a thin brush, and/or cotton buds, and inject with a syringe for stubborn areas at the same time as applying a little heat (old hair dryer). Will not necessarily work on very wide joints (finger boards) without a little persuasion with a flexible palette knife as used by artists.
For furniture joints, that fail to respond to a hairdryer, I use a Karcher steamer (ideal for cleaning ovens) (any brand of steamer - or oven) and this has never failed me.
I tried a steamer and it started to adversely affect the finish on the piece before it freed the joint so I had to find an alternative method.
Thanks for suggestions. I've got a 500w halogen studio lamp and might have a go with that. Can just leave it while I do something else and just make sure it's not getting too hot.
I wondered about steam - pressure cooker produces a nice focussed blast.
It's a very ordinary bit of furniture and it's been caustic dipped so I'm not risking much if I mess it up.
Come to think it would be easier to make a complete new drawer!
heat/steam is your best bet, I would just use an iron and tea towel soaked in water. Might actually be easier to make a new one...
I'd use the heat lamp on the unfinished side, heat until the opposite side is hot to the touch. Then steam the non finished side or dribble warm water into the joint. After about 5 mins to let the glue reactivate it should wiggle apart.
I have watched a few videos by this guy
He uses a hot air gun to take joints apart, and always sets a timer - I haven’t tried to see what settings/timings he uses, but the above video shows him softening some glue at 19mins.
Incidentally, I used this hot air gun technique to take apart some bits, where I didn’t need to be too careful, but it is easy to scorch the wood, hence Tom Johnson’s use of a timer, I guess.
Thanks for that I'll have a closer look. Going to have a go with halogen heat first as it's easiest and can be left to cook slowly.
