galwayworker
Hi, here are two pieces that I have turned recently and I have some questions.
The first bowl is Padauk (130mm diameter, 165mm high). I did some coves by eye on the outside of the bowl, sanded down to 320 grit and finished with walnut oil. A tough wood to turn and the dust gets everywhere… I was wondering should I have tried to fill the grain before finishing as the grain is very open.
The second bowl is sycamore (140mm diameter, 160mm high). Again I sanded down to 320 grit and finished with walnut oil. I cut the blank from an air dried board and I was wondering if the black staining in the bowl is from water staining on the rough board? I’m happy with the wall thickness as this is the first bowl I have turned by myself with such a thin wall.
Any comments appreciated….
J.B.
J.B.
