Trying to match my hifi speakers. Please help.
gperkins1973
12 Sep 2010
Hi there,
I am new to this and would really appreciate anyones advice they can give me to help me match my hifi speakers. I have veneered my subwoofer boxes with American white oak veneer which I ironed on with good success. My speakers are a light cherry veneer which have a orange/yellow appearance. I bought some hard wax oil from a place near where I live which was American and clear gloss. I mixed them 1 part american and 4 parts clear gloss. The applied 3 more coats off clear gloss only. The problem is that is hasn't matched at all. The wax oil was easy to use which I liked.
If anyone has some suggestions as to what I can mix or use I would really appreciate it.
I can't seem to upload pictures. Can someone tell me how please.
The speakers I am using are the Monitor Audio RS6's finished in cherry.
Just google their name to see what the colour looks like.
cheers
Graham
You need to apply stain to get the color match of your wood. In my opinion You need a purple stain to bring the light green color of your oak wood to match with red orange of your cherry wood.
After you get the right color then you can apply your clear coating such as varnish or oil finish.
To find the right stain color you can use the color wheel theory
http://www.wisnofurniturefinishing.com/ ... ishes.html
Good luck
wisno
I fear you will remain disappointed whatever you do with it. Colour matching is difficult to get right both in terms of colour and evenness. Even then, it is unlikely to please simply because oak is open grained and so very different in character from close grained cherry cherry. You might be better to bite the bullet and re-veneer in American cherry. This would initially be a little pale in colour but darkens quite quickly with exposure to light. Applying a finish will make no difference to this colour change.
Jim
Jim,
I managed to match them quite well. I ordered some Antique Yell water based wood stain with some orange wood dye. I mixed 4 parts Yew and 0.5 parts orange and its about 90% close. I then applied 2 coats off clear gloss hard wax oil and its really turned out nice. Stain is coming on tuesday so I will be staining on Saturday.
cheers
Graham
Thanks Jim, Ive never stained anything before so it should be interesting. I found it easy to mix up a small amount to get the colour match. Now I have to use the same measurements to mix much larger amounts so hopefully it comes out the same colour. Ive ordered some sponges rather than use a brush as it looked easier with a sponge.
I would upload some pics but I can't work out how you do it on here.
cheers
Graham
Graham,
It would be good to see some pics. You need the images to be on the web - most people seem to upload them to Photobucket. After that you press the Img button in your forum post, insert the web address of your image then press "close tags". Selecting the preview button at the bottom will show whether it has worked.
Jim
Jim,
Here goes. I have set up a new photobucket account.
[url=http://s864.photobucket.com/albums/ab205/gperkins1973/Wood%20pics]http://s864.photobucket.com/albums/ab20 ... ood%20pics[/url]
Let me know if it works.
I have put some pics off my subwoofers that I have veneered ready for staining. The stain and dye will be arriving tomorrow along with the hard wax oil.
cheers
Graham
Yellowbelly,
missus looks well Laughing
Sorry bit confused, I can't my missus in the pics.
Thanks will post some pics this weekend when I start staining it.
Oh I have two off those big boxes. LOL.
cheers
Graham
Graham, the veneering looks very good indeed. If you have some spare veneer I suggest you glue it to a piece of MDF or ply and experiment with the stain on that before risking the speaker cabinets themselves.
Jim
Jim,
I have a piece which is about 1.5 feet square so I will glue that to a piece of mdf and test what it is like to apply the stain on large areas.
Would there be any problem in staining the box with it upright so I am essentially staining vertically. Its just because the box weighs about 80 lbs and its a lug to move around.
cheers
Graham
Graham,
Can't see a problem with that as long as it doesn't inhibit you from getting a smooth application stroke along the whole surface, which is likely to be the key to an even colour. So, you might need to raise the cabinet a few inches to achieve this. If you can put it on something that will give you a bit of overhang all round that will obviously make life easier.
Lastly, it may be stating the obvious but, if you have any instructions with the product, read them very carefully!
Jim
Jim,
Thanks mate. I will stain my test piece vertically to see how it goes on first.
If it doesn't work it will mean I can only do one panel at time and then turn it when it has dried. Its not the end off the world as I only need to put one coat off stain on it.
Will upload some pics on Saturday.
cheers
Graham
gperkins1973":33ly2ulw said:
Jim,
cheers
Graham[/quote]
thats a link to the photo album - which is why it isnt displaying - you need to link to the actual pics like this
[img]http://i864.photobucket.com/albums/ab205/gperkins1973/Wood%20pics/veneeredsub3.jpg
you cant have any spaces between the img brackets and the url, and the url needs to end in a file extension like.jpeg
Thanks for that. I will be staining it all tomorrow so I will post some more pics.
cheers
Graham
Hi there,
I have just put a coat of wood stain on the subwoofer box and it was really easy. I will upload some pics later.
One question, I have noticed that some bubbles have appeared in the veneer. I guess this is normal as the veneer is soaked in stain. Is it ok to just run the iron over it again (with a cloth between the veneer and the iron) and flatten them down again and should I wait until the stain is completely dry first.
cheers
Graham
Not sure if I am doing this right but here goes. Here are some pics with the stain on. I need to apply my hard wax oil when it arrives as the shop forgot to send it to me.
There's a light patch on the top which is annoying me. I don't know what the best thing to do is as if I apply any more stain it will make it darker. Some advice would be appreciated.
cheers
Graham
Graham,
Sods law always dictates that this sort of thing always happens on the most obvious surface.
I'm no staining expert but I think I would try what I understand many restorers do when patching colour which is to greatly dilute some stain with the appropriate solvent and then build it up gradually it up gradually with thin washes blending it in at the edges. The idea of the thin washes si to avoid a sharply defined edge where any one wash ends. If you try this on some scrap first you can assess the likelihood of success before going for the real thing.
The other possibility would be to attempt to sand it off, but this is high risk; you could sand through the veneer and your chances of getting an even colour after sanding are not great.
Jim
Thanks Jim,
I will try and water some off the stain I have mixed and see if that is lighter in colour and try that on a test piece.
cheers
Graham
