Lons
Saw a GRS-16 in Axminster for £180, lovely bit of kit but too much for me to justify so decided to mock up a DIY jobbie today. A couple of errors, forgot to cut the notches so will have to re drill for the guide bolts and I need to order a clamp like the one in the pic even though it's pretty solid without but I think the square is decent enough to work. A few cuts will soon prove one way or the other.
A bit of scrap 10mm SRBP sheet ( Tufnol ), scrap bit of alu tile trim, couple of 8mm bolts and some d/s tape.
Cut the basic shape, drilled and tapped the bolt holes after very careful setting up, rounded the bolt heads, cut slightly short and cut slot in thread end to take a screwdriver.
Locked the whole contraption in place using a known accurate try square, slid the tile trim under the track base, ( it's slightly thinner than the grip strips so perfect ) marked position accurately, removed the jig and lightly stuck the trim on with double sided tape.
Locked it all in place again, double checked for square and applied pressure to set the trim on the tape. When I have the clamp and have sorted the notches for clamps etc will probably screw or pin the trim as well. Once set up again I'll epoxy the bolts in as well probably.
