Unusual.
The toolmaker's clamp is a good one, and judging by the style of the lettering in 'Moore and Wright', oldish - say 1930's or thereabouts.
The threadcutting blocks are a puzzle. The numbers seem to refer to the block, rather than the thread, because there are seven numbered blocks and six threadforms. From the oxidation, and the style of the lettering, they are oldish as well, though how old I wouldn't like to hazard a guess. They look nicely made, and if the clamp holds them all without any dropping out, they have been very precisely made, so certainly not home-brewed.
The split-block style of die usually come in matched pairs of blocks, with a vee-groove on the side of the blocks in some cases so that they align precisely in the stock. The stock has a pressure screw that closes the dies. That allows the user to cut a thread in two or three passes (as anybody who has tried to cut a coarse thread with a die will tell you, that's very handy!), and to adjust the final size precisely to the threaded hole. That style passed out of use early in the 20th century, superceded by the much more accurate split (or solid) button dies - the round ones.
These are not 'matched pairs', they are a much more unusual 'matched set'. I'll guess that there used to be a special holder, now lost. It might be possible to determine what threads they cut by comparing them with known bolts or similar. Whitworth would be a good starting point, but that's just a guess.
