PerryGunn
On my wooden driveway gates, I have adjustable hinges (3 per side) and occasionally need to wind the hinges in/out a little to keep them aligned
The hinges are this type with 32mm nuts
Loosening off the outer nut is easy but, because of the coach bolt head behind the thread, there's no clearance to get a long 32mm socket over the inner bolt. There's not enough room above/below the nut to use a normal spanner and anything that I have with jaws that will open wide enough will not fit far enough in between the nut and the top/bottom plate to grip the nut properly.
I've been coping with this by lifting the gate with wedges to take the load off the hinges, fully loosening the outer nut and managing to turn the inner nut bit-by-bit with my fingers - this gets a bit painful after a while - and then retightening the outer nut.
I'm sure there must be a specialist spanner or set of grips for this sort of thing but I haven't had any luck finding anything that I can be certain will work
I'd be most grateful if someone can point me in the right direction
Perry
![Hinge.jpg Hinge.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/76/76735-Hinge.jpg)
Perry
