Thanks for all the info from everyone, but i'm even more unsure than when i started.
1 What is the proposed use of the building. - The building will be for a toilet/shower block on my campsite.
2 Is the building habitable. No, probably summer use only, but not habitable.
3 What are the ground conditions - Good solid ground conditions, 150mm of compacted gravel, layer of sand, DPM & 150mm Concrete slab
4 Is there drainage in the building- 50mm water drainage from showers/basin in slab, and waste/soil drainage 110mm vertical pipes accessing toilet areas.
5 Is there a screed or loose floor finish - No, tiling straight onto concrete slab once ready
6 Is insulation required in the floor, also cold bridging problems. - No insulation in floor
7 What form of services are there – 50mm water drainage from showers/basin in slab, and waste/soil drainage 110mm vertical pipes accessing toilet areas leading to outside septic tank area
8 Form of roof spanning onto external wall studs and so stud sizes and holding down for strength. Timber frame panels - 100mm x 50m at 600mm centres, and roof truses at 600mm centres
9 Are there internal walls to break the roof spans and loads. - Central partition lengthways down the centre and another partition across the width (please see diagram attached)
10 Is a dpm required under the slab – 1200 grade DPM under slab
11 The expected loading on the slab- Other than building, light traffic, people going to the toilet, and having showers
12 Is the Bldg. Regs. (in Scot.) of 150mm distance between ground and dpc the min. required. - Need to ask BCO, initial conversation suggested no, as it's not a habital dwelling.
13 What form of rainwater downpipes to be provided- trenches adjacent wall base/founds. - hunters rain water good, and french drain all around.
I4 Is a structural fire rating necessary. - My structual calcs dont mention it
15 Is there an internal finish. P/b has been mentioned. - PLasterboard interior
16 Is there a finish to the slab edge – a render, board, and so. - ?
17 Is the slab to be waterproof.- ?
18 Should the external boarding be spaced on runners for ventilation. - all cladding will be on treated 25mm x 50mm battens
19 Wall fixings to slab to withstand the combined roof loads, wind loads, uplift, and dead loads. - i intended to bolt it down as you first suggested?
20 Is there a need to sheath the studs after the above is resolved- re. for struct. racking. - I'll be steathing the studs with OSB 3 9mm, then a breather membrane
21 Does it have an agricultural use. - NO
22 Is there exemption from planning and building regulations. NO
23 Height of studs. 2.4m
24 walls made up in panels or sticks re. form sole plate and holding down. - Timber panels
25 floor loading re. thickness and reinf.
26 and so on, and so on.
Twothumbs, your original suggestion stated that if i was to use a single or double course of bricks on the slab, it could be a nuisense and bump loose. With this in mind, i want to avoid this?
The frames will be made of untreated timer, but should i use treated wood for the sole plate?
Or, could i bolt a layer of treated timber on the concrete base, and than attach my untreated timber frame panels to this?
And with regard to the DPC and DPM position? I take it putting the DPM up the outside of the building, and breather membrane over it, may not be the best solution? What if i placed the DPM on top of the concrete slab, but under the timber frame and attached it to the inside of the building would be a better solution?? (please see Timber frame DPM inside building diagram)
Any help on this subject would be really grateful. I must admit, i'm slightly more confussed than when i started.
