Melinda_dd":ugqy63x1 said:
jpt":ugqy63x1 said:
Looking at Timberbits site you have a multi kit there to make either a single or double ended ripper. There are instructions on the site, go to the bottom of any page and you will see a link in one of the lists, but they dont explain why the extra tubes.
As Naz says I think it is dependant on what you make, doing a quick measurement on screen if you did a double ended one the long tube isnt long enough so you would need to add at least one of the tubes.
Hope that makes sense and helps.
john
Just tried and they both fit in the bigger tube not a problem.... hurty bits inside the tube that is
Not made one but from some of the information you have given.
If you make a double ended ripper you insert the small tube inside the long one and put the two gripper strips in from either end so to take the ripper and pointy tool(don't know what that is for. That way when 1 is being used the other is reversed, or both can be reversed for storage.
If you want a single ended ripper them the longer of the short tubes is put in and only 1 of the gripper pieces used the blank end is then blocked off with the clip part.
Hope some of that makes sense.
In other words the two small brass tubes are there to prevent the gripper spring from disappearing into the opposite end of the main tube
