in an effort to make use of the delivered chuck and jaws (rather than give up and return them - see thread on dakota X450) I have tried to establish exactly what the underlying chuck threads are to give me the widest choice of alternatives.
using somewhat rudimentary measuring devices it would seem that the narrow part of the female thread is 1 3/8" and the widest part just over 1 1/2". It's clearly 8 TPI rather than a 3.5mm pitch.
the male dimesions of the the supplied insert are easier to measure and are 33.5/37.5mm which are just slightly below the above dimensions.
would I be right to conclude that this represents a 1 1/2" x 8tpi thread?
is there a tree somewhere that grows 1 1/2" x 8tpi -> 3/4" x 16tpi internal inserts?
could I aquire a 1 x 8 f to 3/4 x 16 f internal adapter instead - this isn't intended as my heavy chuck solution! do these exist? (the only link I found in hours of searching was to pencrafts 2 months ago but has now gone (I have written to them).
I'm fairly confident that the actual chuck is a copy of the Penn State Ind Barracuda, but the copy may not include the threading, and even if it did the aquisition of an insert from there isn't going to be economical.
thoughts, guidance etc appreciated
