sawdust maker
Some of you will have seen, in Projects, that I am making a breakfront bookcase. The base board is made from 18mm Birch ply. The centre section will be a drawer unit with cupboards at each end. As most of the real wood used is South American Mahogany and the ply will be exposed at the bottom of the cupboards. I intend to veneer the this section of the base board. My question is do I need the veneer underside of the base board, or can I get away with just doing the top which will form the bottom of the cupboard.
Paul
Paul
