ByronBlack
I'm going to be making some smallish wall cabinets for family xmas presents using some of that nice spalted maple I recently bought. I'm just finishing of the design and working out dimensions, and have stumbled across a problem that I've been unable to find a solution for on the net or my current limited book supply.
I wish to make a frame and panel door. Is it unwise to make the frame out of 15mm thick stock and routing a 5mm groove to accept the resulting panel? My initial plan was to go with 20mm thick stock, but the sycamore I have got won't provide with that thickness once re-sawn (its 37mm thick - I don't want to plane away the other 17mm).
Finally, I've also decided to go with 15mm for the carcass panels (side and top/bottom) is this acceptable, or should it be thicker?
For reference the cabinet will be 350mm tall by 210mm wide.
TIA
TIA
