The Barron Blade
woodbloke
13 Apr 2006
Salisbury, UK
Has anyone seen the d/t marking knife project in the latest F&C? Looks very good so I may well make on later on...need to source some of those scalpel blades firstly (I know that PFT have got a selection) - Rob
Rob, I haven't seen the article but if you're after a few scalpel blades I might be able to help. Which blades are used?
xy
xy
The blades used in the project are Swann Morton SM01, quite chunky by the looks of it and apparently 0.6mm thick - Rob
woodbloke":2lg4i41q said:
xy mosian":2lg4i41q said:
Sorry Rob, not one of the ones I have.
xy
No worries, xy, thanks for looking, I'll have a quick nose round PFT next time I'm in town - Rob
I assume the bevel is on just one side, however I don't see how they can be arranged for left and right hand cuts, it's probably me.
newt":235tnmri said:
woodbloke":235tnmri said:
xy
Pete - the bevel on the blade is on both edges...Barron seems to disregard this fact in the text which I find odd :? as there will be a very small discrepancy (ie half the thickness of the blade, 0.3mm) when it's used single edged for marking out. I don't know though if this would make any appreciable difference to the accuracy of the joint? - Rob
I suppose you could always hold the knife at a slight angle when using it, so that the bevel is in contact with the straight edge :-k
Cheers :wink:
Paul
I'm not sure about the accuracy argument. I use Swann and Morton scalpel blades (although not the one you referred to) in my marking gauges. These 10A blades are .35 thick, half of which is 0.175 which I can't see as being significant.
I know that a single bevel blade is best, but where an element of disposability is wanted the scalpel blade is a good choice.
Ed
Paul Chapman":1464ntjf said:
woodbloke":1464ntjf said:
My thought as well Paul, but it does make it slightly more awkward to use - Rob
Yes, much better to use blades beveled on one side.........
Cheers :wink:
Paul
...which is why a knife with a 'V' point ought to be better - Rob
The Barron blade is epoxied in, so not very disposable?
On reading the article I had assumed they were single beveled and was probably confused when he showed sharpening the "back" (which was really the top) and fitting the blade correctly for the correct hand (I suppose he was referring to the thumb depression?)
Will probably find out for certain tomorrow when my blades arrive?
Wonder if they will fit my Veritas holder?
Rod
Rod
Rod - this is the thing that was getting me confused. The blades are conventional double bevelled scalpel blades. The thumb depression is a neat idea and makes the knife 'handed' but thinking about it a little more, I'm not sure it's the 'ultimate' d/t knife simply because of this bevel issue on the blades - Rob
I thought the whole object of a good marking knife was single bevel, which is more accurate as you can hold it vertical which is useful when marking small pins. Perhaps it does not matter after all, an over hyped parameter :eek: .I found when I used a scalpel that I tended to sometimes cut into the side of the tail, which I think may have been due to flex, this may not be the case here as Davids blades are thicker. The thing that surprised me was that they are fixed in the holder, not disposable.
Alf":1y6sky3c said:
Jeff Gorman has an interesting take on the matter of bevels on marking knives; worth a read. I also seem to recall scalpel knives being considered to give too thin a line?
Thanks Alf, I have to pencil in my cut lines anyway, its an age thing, I think.
I don't think these are scalpel blades as such, just similar looking, and made by Swann Morton. http://www.craftknives.co.uk/products/smo_r.html
I wouldn't want to build one in to a permanent holder, even if they are very beefed up from a scalpel blade. Especially when that Swann Morton holder is about £2 and would allow you to change the blade when it snaps or dulls (and at 6p each, I would avoid the sharpening). But then I'm a heathen and fairly immune to african blackwood etc.
