Wouldchuk
Hello all.
I've been making a small table, which will have a drop leaf, and will sit up against a wall.
The top I made from 1inch planed American white oak which i'd bought ready-planed and were straight and true at the time when I biscuited and butt-jointed them together. The top is around 800mm by 450mm, with the drop leaf 800 x 300mm.
In the long lag between getting on with the job, the time spent in the workshop has led to the glued-up top cupping significantly, with around 5 - 10mm of deflection from the centre. The top is cupping upwards, creating a 'bowl' like shape if that makes sense (although it's obvoiusly not that bad!). If you run a straight-edge across the width, and measure down to the centre, there is 5mm or so deflection.
I'm now pondering how I correct this - there seems so much deflection that if I plane the edges down until level they will be quite a bit thinner than the centre. But is that the only option?
I was thinking of making a simple router sled and using it overhead.
Advice?
Advice?
