Table Saw Router Bench - What saw ?
ChrisJ
17 Nov 2016
Norwich
Hi guys n gals
I have an Incra router table that I want to adapt into a saw/router combo.
The table is a bit awkward to use as its top is too deep for my shop so I am thinking i might make a new top and drop the router lift in it, simple :)
So Im then thinking that instead of buying a separate table saw machine and attaching it to the router table. I might be able to use a saw and motor assembly and drop it into the new table in the same way that you might drop a router lift in.
I hope that makes sense.
If it does you might be able to suggest a unit or should i buy a site saw and discard the top.
Thanks for any help and advice.
