Table Saw height adjustment
Hemsby
9 Dec 2013
Lincolnshire
Hi,
I have a Dewalt DW745 10” table saw, it is suitable for my needs but the only problem is trying to get some sensible depth of cut adjustment :-k .
My question is does anybody know of a retro fit gadget that can be fitted to the height adjustment that enables some degree of measurement for the depth of cut.
Keith
marcros":2w06cmqf said:
something like this or the manual equivalent?
http://www.wixey.com/heightgauge/
Thanks for that, shows how it helps to have other thoughts. I automatically thought of a dial to attach to the hand wheel #-o .
I did not think in that direction especially as I have a number of measuring instruments left over from my engineering days.
Will check to see if there is anything available on a UK site if not will adapt one of my instruments.
FOUND THEIR UK SITE :D
Regards
Keith
Myfordman":15qoq5el said:
Keith, If you want to use your engineering background then you might be interested in this
http://thewoodhaven.co.uk/phpBB3/viewto ... =19&t=1497
The complexity of making the measurement on a tablesaw is because the blade arbour moves on an arc rather than a straight line.
MM
Thanks for that info, I will have a look in the bowels of the saw Tomorrow at the possibilities.
I am thinking of something like the product in the link that Marcros suggested. I have found a spare DTI with a 2" travel that I could mount on a block which would bridge the blade area allowing the DTI to touch the tip of the blade, locating the contact point at the crest of the blade should not be a problem (probably a good idea to stop the blade when I check[-o< [-o< [-o< )
I would prefer a fitting like the one in your link for obvious reasons, depending on the practicalities & work involved.
Its times like this I wish I still had my Factory, endless supply of Machines & raw materials, but then I would not have the time to play =D>
regards
Keith
This is mine:
It's accurate enough for a TS and an RT.
S
    48.3 KB
MM
Hi,
Disappeared in to the darkest depths of my TS and it lends itself perfect for a modification to provide a up/down calibration scale, or it would if I do not want to cut at an angle.
The blade is a nice straight up and down movement and it would be easy to fit a connection from this through a new slot cut in the side of the casing to a scale.
The problems comes when the blade is tilted, the whole assembly moves which would displace the new connection through the case dramatically, no doubt I could overcome this with a series of connections, but life is too short.
I think the direct measurement from the blade is the answer.
Keith
