if you bought it new, i would speak to the supplier. If it is axminster, see what they suggest. If they want to replace it, ask them to check the new one before sending it. There is only one review on the site, so it is difficult to know whether the saw is prone to the problem or not.
you may be able to put a shim in to the clamping part so that it clamps straight- it sounds like one side is clamping before the other and pulling the fence out of square. The problem remains that it moves when you clamp, so may be a faff having to measure each cut rather than using the scale. I measure on my bandsaw because i struggle to read the scale- it isnt the end of the world.
On a saw costing a couple of hundred quid, including manufacturers profit, import costs, transport costs and dealer profit, there is always going to be a comprimise. unfortunately it is often the fence. Hopefully you can sort it- the jet looks a handy thing with its rear extension. If you cant and have to return it, i would look at the secondhand market. you shouldnt have to spend much more to get something that will meet your needs. The forum can help if you go down that route with suggestions and what to look for.
