smartecosse
So, I've had a read through the various threads on here and still a little unclear.
Mainly I am going to be cutting 18mm or thinner plywood.....do I need to invest in a set of blades or would a combination one do to start off with.
Don't really want to spend a fortune on some new blades and not planning on doing any delicate work that would need a super fine cut.....
Will a decent combination blade still be able to do long cuts albeit at a slower speed as I will be cutting down some larger panels.
Unfortunately the blades that came with the saw don't look that clever, except the scorer blade which looks okay. The finer of the two blades is actually missing parts of the teeth.............guess I should have had a look at the blades when collecting but I was more concerned how to get 450kg into the back of the van!
