Sgian Dubh
pe2dave":32fgwcpo said:I've been using 60tpi blade for ripping and x-cut.
Is the 50+ pounds a good price for the Trend blades (10")?
Sounds a heck of a lot.
Trend do supply a good product and their prices in my opinion are fair, particularly if you're running a blade hard and for long periods. On the other hand Freud also make good saw blades, router cutters, etc. Like Byron I've found Freud blades perfectly acceptable, so if that's within your budget I'd spring the cash for one of them.
Definitely your 60 tooth blade isn't suitable for ripping. I'd hazard a guess it's probably an ATB blade, maybe even a high alternative top bevel (HATB) designed for fine cross cutting, quite possibly even for cutting melamine faced board materials and the like.
If you can live with a compromise you could go for a general purpose blade, and on a 10" diameter blade it will probably have between 34 to 46 teeth with a fairly low angle ATB pattern tooth, perhaps 3º- 5º. It won't rip as well as a dedicated rip blade and won't cross cut as effectively as a true cross cut blade, but it'll do a bit of both reasonably well. Slainte.
