T Track Router Bit
martynbez
5 Sep 2019
Medway
Hi,
Does anyone know what is the best router bit for routeing out a channel for T Track is?
martynbez
5 Sep 2019
Medway
Ok I have brought the track and want to make the groove in my work bench for it to sit in. I assume routing the groove in is the best way?
So if this is the best way what would be the best router bit to use?
Hope that clears it up :)
Trainee neophyte
12 Apr 2019
Greece
Aha!
I would assume a straight bit, of the relevant size would be best (the slot would probably be 19mm internal, but the width of the track itself? I have never done this, so I am now going to step back and let a real carpenter answer, because destroying your bench would be more responsibility than I could cope with.
(homer) (hammer)
Mowgli
16 Aug 2019
Sheffield
I have mounted T tracks by using a track saw to cut the sides of the slot to very-slightly-deeper than required, then using the router to take out the material between. I find the track saw gives a better cut than the router, but I don't see why you couldn't cut out the slot one side at a time using say a 12mm or 16mm router bit. I probably wouldn't want to do a full depth cut, but take it down gradually in 2 or 3 passes.
martynbez
5 Sep 2019
Medway
Hi! Yeah did it with the router in the end. As you side 2/3 passes and it cut a nice channel. Ways a good challenge.
