T Track Router Bit
Ok I have brought the track and want to make the groove in my work bench for it to sit in. I assume routing the groove in is the best way?
So if this is the best way what would be the best router bit to use?
Hope that clears it up :)
Aha!
I would assume a straight bit, of the relevant size would be best (the slot would probably be 19mm internal, but the width of the track itself? I have never done this, so I am now going to step back and let a real carpenter answer, because destroying your bench would be more responsibility than I could cope with.
(homer) (hammer)
I have mounted T tracks by using a track saw to cut the sides of the slot to very-slightly-deeper than required, then using the router to take out the material between. I find the track saw gives a better cut than the router, but I don't see why you couldn't cut out the slot one side at a time using say a 12mm or 16mm router bit. I probably wouldn't want to do a full depth cut, but take it down gradually in 2 or 3 passes.
Hi! Yeah did it with the router in the end. As you side 2/3 passes and it cut a nice channel. Ways a good challenge.
