J_SAMa
This chisel seems quite odd to me, it being nearly 13'' long and all (blade alone looks like 7''). Is this really gonna put up with the abuse from heavy morticing?
undergroundhunter":nh7t198p said:My Nerex mortice chisels are about that long, never seemed to bother them.
Matt
J_SAMa":2pyjg972 said:undergroundhunter":2pyjg972 said:My Nerex mortice chisels are about that long, never seemed to bother them.
Matt
Well they might have the same overall length but the blades on Narex's look much shorter...
matthewwh":thc6oag4 said:Hi Sam,
It's hard to tell from such a small photo (picturetje?) but I'd take a punt at it being a paring chisel - they don't have to be bevelled.
AndyT":20j9wfb4 said:Sam,
If you had said at the start that it was just something you had seen on ebay, this question would have been a lot easier to answer!
Here is a larger picture
and here is the link to the original listing where you can see it even bigger:
http://www.ebay.co.uk/itm/5-16-mort...d=100011&prg=1005&rk=2&rkt=5&sd=151114930581&
where the seller describes it correctly.
It is indeed a sash mortice chisel, used where the mortice you want to cut is shorter (front to back) than it is wide (side to side), so a common mortice chisel would be too deep.
If you look at my 1938 Marples catalogue (see this thread you will find them on page 14, listed as "London Pattern Sash Mortise Chisels" available unhandled or with a box or beech handle, in 10 sizes from 1/8" to 3/4".
So, to answer your original question, No, it would not stand up to abuse from heavy mortising - it should not have to, as it was designed for relatively light mortising!
