WoodMangler
I have some odd marks I don't understand. I've turned this bowl from tulipwood (first time I've used it), about 6-1/2" diameter. I turned it in the usual fashion. I sanded to 600 grit, mainly with a rotary sander, and then Nyweb'd it to yellow (which is, I think, 1000 grit), I applied shellac sanding sealer before the final yellow nyweb. I then washed it off with white spirit. At this point it showed none of the marks that have me puzzled. I then applied 4 coats of boiled linseed oil - apply thickly, wipe off excess after 1/4 hour, re-apply after another hour. This is the first time I've tried an oil finish, previous turnings have all been finished with a polish of some kind.
I've ended up with two light marks running across the bowl - in the upper picture it's left-to-right, and the lower picture it's top-to-bottom. The marks occur in the same place on both sides of the bowl. Are these marks to be expected and, if not, is there any way I can get rid of them before I apply my final polish ?
