Hi Phil, this has been one of my biggest head scratching projects..'how to finish the epoxy, stones and wood' ](*,) I know im not doing myself any favours wanting to use tigers eye as it has a hardness of 7 on the MOH scale.. in fact Ive got a head ache just thinking about it now.. my plan is to fill any of the small voids with different sized stones so they only just protrude the surface then pour the epoxy over them, then, once set sand over them with different grades up to 600 grit, then polish. In the centre of the table where the large infill is I will do the same but using larger stones aswell.. i think the only finish i will be able to use is a 2 part poly or epoxy resin.. Woodaxed, thanks for your comment on my mirror, this table top is from the same cut of the tree. the reason i want to use tigers eye is for the colours and lustre they have (I'm hoping i can create the same lustre as tumbled stones once ive finished) i will defo be practising on offcuts first. :wink:
