Stattrite table saw.
Tunstall
New member
5 Nov 2023
North Wales
I have a startrite145 table saw and have a problem with the tilt ambor
adjustment being very stiff to operate. Any advice please.
Based on APRON BLADE HEIGHT TILT MECHANISM - Machine Spares it looks similar to the 175 mechanism (of which I've rebuilt a few). The universal joint could be failing, the nut/feedscrew could need lubricating (or could be clogged with a mix of saw dust and grease), or the half circle section on which the shoes ride could be clogged/jammed/damaged.
They're not actually that hard to take apart, and it's well worth doing some maintenance.
A full manual is also available here: Startrite Saw Spares and Handbooks | Sharktooling | Spare Band and Circular Saw Blades and Cutting Fluids
I'll check the joints and half circle many thanks
