Staining & waxing
load2go
25 Sep 2014
Durham
How to get the best result.
When staining and waxing pine would it give the best result if after staining to lightly sand before applying the wax?
Thanks in advance
i would put a coat of sanding sealer over the stain or you will be waxing daily forevermore.
I have just started using Tru Oil and am very impressed with the results. After sanding down to 320, I use sanding sealer and then sand lightly to 400. Then Tru-Oil and two coats give a good result, but I want to wipe on a third coat before waxing with microcelulor wax. I believe the results will be an improvement from just a few coats of sanding sealer and then waxing.
