Square Strip Making Router Jig
ByronBlack
4 Sep 2005
Thurrock, Essex
I'm currently without a handplane, bandsaw or tablesaw. And cutting thin strips to use as sliders is too diffiucult to do with either handsaw or circular saw, so I decided to quickly knock something up for the router table.
It uses a piece of MFC to provide the straight edge and a pattern bit to follow said straight edge.
I've used some old scrap laying around the shed to create a guide, and a stop - and a piece that is screwed onto the top to hold down the piece to be cut.
I've added sandpaper to the edge of the top hold-down piece to keep the piece to be cut nice and snug while it goes through the router.
I'm using this one to cut 12mm square strips which will be used by the router-fence that I'm making.
Piece rough sawn ready for routing to size:
Strip placed into the jig - you can see the stop at the end.
Sandpaper doubled-side taped to the end of the hold-down.
Hold-down screwed to the base holding the strip nice and snug.
Strip ready to go through the router - mu guard is moved closer in - it also doubles as a chip collecter with an extractor attached.
The strip is cut on one face, turned over and done on the other face to get a nice 12mm square strip.
Two strips cut ready to be used as sliding guides for my new router-fence.
Hope that helps someone get out of a bit of a jam.
Even if you had a bandsaw (my preferred way of doing these) this is a good method to get a nice clean edge 90 degrees to each other, and it's very easy to make a few of these jigs for different width strips. It probably wouldn't be that difficult to make an adjustable one.
