Spokeshave
doggerry
9 Mar 2013
Nottingham
Hi
I am pretty new to woodworking and really green when it comes to hand tools. So I was wondering if anybody could help me.
I have started to make an electric guitar from mahogany and have cut out the body with a band saw. As you can imagine it is pretty rough. I was hoping to use a spokeshave to smooth it out but have no idea which one to buy. I was looking at an Irwin Record one but I am not sure on the type.
any help would be appreciated.
Ged
Hi
If you are referring to smoothing the profile cut at the bandsaw I'd consider using a sanding drum in a pillar drill if you have them.
Regards Mick
The cheaper versions of new spokeshaves are probably best avoided. The blade beds are sometimes not very flat or well finished, which means the tool is very prone to chatter in use. Older examples (older the better!) where better made, so are a better bet to start with. There are some very good new ones available (Veritas, Lie-Nielsen, Clifton) but the price matches the quality. You'll only have to buy one once, though.
One positive is that secondhand spokeshaves (except some of the collectable rarities) are not expensive to buy secondhand. Ebay has loads of them, or a reputable dealer (see Alf's list of dealers on her website cornishworkshop.co.uk )will sort you out a good example on request.
Sharpening a spokeshave blade can be tricky unless you use a holder of some sort. A block of wood with a sawcut in it to wedge the blade in will do - it's just to get a comfortable hold of it and keep control of bevel angle while honing.
As a 'left-field' option, the old wooden skokeshaves are an option, too. Sharpening these is a puzzle at first; setting the blade on the edge of the bench and using diamond files or slipstones, or progressively finer grades of wet-and-dry stuck to small flat sticks of wood, will get you there. Depth setting is done by tapping the horns of the cutter in and out with a small hammer - you can set a wooden spokeshave with great precision with very little practice. They're cheap, too, so getting a selection of sizes is very useful and won't break the bank. Look out for the ones that have had brass inlaid into the mouth area - they'll last longer before needing re-mouthing.
Spokeshaves can sometimes be persuaded to cut more cleanly by skewing them across the timber being worked. Useful when you get awkward grain.
Very handy tools to have on hand, spokeshaves. They come in for all sorts of shaping jobs. Building up a small selection of them would be well worthwhile, and need not break the bank either. Good luck!
Thanks for the replies. I have decided to go with the option of drum sanding for now, but I will be investing in a decent spokeshave as I really fancy the option of learning to use proper tools.
If it was me i'd go for a drum sander or something like that, mabye the roller end of a belt sander. Spokeshaves get quite hard to use cutting at full width which im presuming your guitar is.
I use a series of different diameter drum sanders mounted in my pedestal drill. I have a sub table with removable discs of different diameters to suit the drum sanders. You will use a spokeshave for the neck. I am waiting for an offer then I shall buy a pair of Quangsheng spokeshaves.
