BigShot
Hi folks.
I've got a double bed frame I'm trying to fix up. Nothing amazing, but in generally good condition but for this crack (see pictures).
Both splits just apparently disappear into good wood after a short run. I'm calling the main one that breaks the board-edge the primary split and the smaller one running from just below the main knot the secondary one.
Any advice on a structurally sound way of fixing this?
Preferably using standard wood glue so I'm not having to run out to buy resins.
Lacking a better word, the beam down the middle (which carries the midpoint of the laths) is received by the block you can see just off to the left of the shot in the "Interior" image attached to this post. So it's got to carry some load.
I know it's possible to drill and dowel the end of a split to keep it from running further.
Is that the best way of going about this though?
I thought about finishing the split and then gluing the piece back in entirely but I have a feeling that it will follow the grain in the wrong direction and split the piece in two. Not a repair I relish the idea of engaging in if I can avoid it.
Any input greatly appreciated.
Cheers.
Cheers.
