Spline Joint?
sxlalan
21 Apr 2005
Skipton, Yorkshire
Hopefully this will be the last question required to finish off the cot I am building :roll: (thanks for everyone’s help/patience!). I have the basic cot finished now and just need to attach a hardwood frame around the top (primarily just for looks). The frame consists of 60mm x 21mm lengths of beech which will run around the entire top of the cot (roughly 1400mm x 700mm). The frame needs to be connected to the cot itself somehow, and in the absence of a biscuit cutter I was contemplating a spline joint. The cot itself is made of poplar and the pieces in question (the rails along the sides of the cot and the top of the head/footboards) are also 60x21mm so the connection will be something like this
I am thinking of using my router to cut a 6mm wide, 10mm deep groove along each piece and inserting a matching piece of ply as the spline. Does this sound reasonable? The beech and the poplar are joined long grain to long grain so do I have to worry about expansion or can I get away with a spline glued along the whole length of each piece? Is 10 mm a reasonable depth and am I OK to put a single long spline in (eg for the whole length of the joint) or am I better off with multiple small splines?
Thanks for your help ... I'll post some photos when it's done!
Alan
Philly
24 Nov 2003
Dorset, England.
Alan
That sounds fine to me-although if it is long grain to long grain you really shouldn't need to re-inforce it. That is the strongest bond when gluing wood together.
Philly :D
SammyQ
12 Apr 2005
A wee house on a hill
Wot say you to putting a biscuit cutter in your router, cutting continuous trenches along the edges of your timber and gluing in some of those LLLLOOOOONNNNNNGGGGGG 'biscuit'/splines sold at a number of outlets?
sxlalan
21 Apr 2005
Skipton, Yorkshire
Thanks guys.
Sammie, I don't have a biscuit cutter but have a 1/4" straight bit so was going to go with that.
Philly, I was just worried that with the beech forming a frame around the top it is likely to get leant on quite a bit. Is the general consensus that glueing alone should suffice?
Alan
CHJ
31 Dec 2004
Cotswolds UK
sxlalan":yvv1ftdb said:
...snip..Philly, I was just worried that with the beech forming a frame around the top it is likely to get leant on quite a bit. Is the general consensus that glueing alone should suffice?
..snip..
As long as you can clamp the pieces true to each other without the assistance of the splines, & with even pressure along their length I would suggest that a modern adhesive will as Philly says, be as strong if not stronger than the wood itself.
Have you a couple of short sections of scrap that you can glue up to prove the point to yourself?
sxlalan
21 Apr 2005
Skipton, Yorkshire
Hi Chas
I should be able to get some scraps together :) Are we talking PVA here or something else?
Alan
A
Anonymous
Guest
Alan
Dowels might be a nice and easy way to add strength to the joint
CHJ
31 Dec 2004
Cotswolds UK
sxlalan":cuztowbn said:
Hi Chas
..snip..Are we talking PVA here or something else?
..snip..
Fine as far as I am concerned, others will soon let us know if I'm wrong.
I have yet to part a joint made with it whithout tearing darn great splinters off one piece or other of the wood.
See Here for some general info. on adhesives and for a Forum Thread by Chris Waterhead on the subject.
