Quantcast
Spinning a bowl
NickWelford
So many tools, so little to show
6 Sep 2006
South Lincolnshire. UK
Really not sure where to put this topic. I have a wood lathe and want to try spinning a copper bowl on it. I’ll need to turn some kind of wood former so maybe it belongs here!
I’m aware of the process but haven’t plucked up the courage to try it yet. I have a ready supply of copper sheet, so I can cut a disk and anneal it.
Has anyone actually tried this? Is it worth the effort or shouldn’t I bother and just raise a bowl with a hammer? Any takers?
clogs
just can't decide
24 Jul 2020
Vamos, Crete, GREECE.......
the prosess is called metal spinning....
ur wood lathe wont be man enough unless it's like a Wadkin RS......
most metal spinning is done on a special or modified Metal Lathe.....
not so many doing it now, mostley done with a press and tooling.....
for me I'd raise the bowl by hand....look at siver smithing on Y/tube.....
basically a former and a hammer......end's up hard work......
NickWelford
6 Sep 2006
Yes, Clogs, that’s what I normally do. I am a sort of silversmith and coppersmith as well as a wood butcherer. Not that I’m particularly good at anything. I just fancied trying it. Annealed copper is pretty soft, so I wouldn’t have thought it was that difficult. Guess I won’t know until I try it, but was hoping to pick some brains.
Cooper
27 Jul 2016
Bromley Kent
I spun a copper dome when I was at teachers training college 45 years ago. I wanted to make a mould to form expanded polystyrene domes in. As mentioned above I used a very tough lathe even more solid than my graduate . As I remember It had a live centre to press the metal onto my pattern which I turned from beech. I threaded my pattern blank so it screwed onto the thread of the spindle and turned it to shape on the same lathe. As I remember there was a pretty strong post in the saddle that I pivoted the spreading tool against. The tool was basically a steel bar that the end had been rounded and fitted into a blooming big handle which I think I had to tuck under my arm to hold it steady. You mention annealing the copper, I had to do this quite frequently and quench it in the acid bath. I only made one incompleat dome from copper as it was really tough going. The tutor suggested I try aluminium as it was much softer, which I did. The ally had to be frequently annealed as well, which was a bit of a game taking the piece off the lathe and centreing accurately when it was replaced. I made a larger hemispherical dome 250mm diameter with a 50mm rim, then turned the pattern down by 10mm or so and turned the inner part of my mould. All the time I was doing this the tutors and technicians stood well back and told stories of when they were in arircraft factories in the war making the noses of planes and the disks coming loose, flying across the factory and out through the wall.
I made my polystyrene domes, cut them with a hot wire and then cast the pieces to make an aluminium 3D jigsaw puzzle. I still have my mould and the pattern somewhere but the college kept the jig saw puzzle in a display case as nobody had ever done anything like it there before and the college had supplied all the materials. Those were the carefree reckless days and time seemed to run much slower or days were longer!
Jonzjob
19 Mar 2007
Ex nr Carcassonne, S France. Now NW Wilts, UK
The only metal I have ever turned was spindle turned ali rod and that was quite something and not difficult. Just using a 3/8" spindle gouge and slowly slowly catchie monkey. A tiny bit of small brass rod, but I would think copper would possibly clog any normal wood turning tools.
I can't imagine how you can turn a sheet of any metal into a bowl without a good deal of belting ?
Paul Hannaby
1 Sep 2011
Gloucestershire UK
I have spun copper, aluminium and pewter and all are possible on a decent woodturning lathe. Copper around 0.5-0.6mm thick wasn't too difficult. I did try some 1.2mm sheet and decided that was pushing things a bit far although I did get some results with it.
Phil Pascoe
29 Jan 2012
