I have purchased an old cast iron lathe, and am going to order an insert for my Sorby Patriot chuck (that has an insert to fit my old lathe).
I'm a bit confused, after trying to measure the thread size. It seems to be 1 1/4" x 7 TPI. This seem to be an unusual thread size. 1 1/4" x 8 tpi is available at Sorby, as well as 1 1/8 x 7 tpi. But this size seems odd.
I measured the threads with a Whitworth thread gauge (that usually works for both Whitworth and UNC threads).
Not sure if it's Whitworth or UNC however. I have no means to measure if the thread angle is 55 or 60 degrees. The threads seem to fit the thread gauge quite well, but that does probably not mean much.
