Aragorn
Hi all
Little help please.
I've just been reviewing the posts here about getting a tough heat/water resistant finish, for a table top.
I have a couple of kitchen table projects on the go (one in cherry, one in elm) and would like to clarify what finish you guys recommend. Spraying isn't an option and I'd like to avoid poly varnish (unless this is the best alternative?).
Is finishing oil the way to go? How many coats would you recommend. And how are you cutting back between coats (i.e. how fine a grit? Wet? Dry?)
Thanks for your help and sorry to be going over old ground.
A
Little help please.
A
