matthewwh
David C":2xj765ab said:Karl Holtey certainly does not agree with this thesis. The 98 and newer version have blade support solely at the heel of the bevel and a single point pillar further back.
I had an infill plane once where the timber had shrunk and the heel of the bevel was not supported. It was unuseable.
The bend imparted to the blade by 95% of all capirons seems to be a good thing. Just an alternative point of view.
Best wishes,
David
Alternative views always welcome!
I would point out though that Karl uses incredibly thick cutting irons and very low profile cap irons which suggests to me that he is designing to maintain as flat a surface as possible. I can see the attraction of his tricycle bedding arrangement which provides failsafe stability in the same way as a milking stool - provided that what you are clamping to it has mass and stability engineered in already.
Clico freely admit that their solution is over-engineered for standard use, but when you are using steeper angles for example it's reassuring to be starting out with something that is built like a tank.
