Soldering
WonderWoman
28 Jun 2005
South UK
Probably the wrong forum to try but anybody do any soldering?
Im looking for brass/chrome soldering ribbon,any ideas?
Scrit
17 Sep 2002
Soldering is normally done using something like lead or tin - which melt at a fairly low temperature (I vaguely remember it is around 188 degrees C with the soldering iron temperature about double that). Brass requires much more heat and the use of a (gas) brazing torch, at around 450 degrees C. Dunno about chrome, although I've used nickel rods for brazing cast iron in the past (similar appearance to chrome) - anyone in the know? Didn't think you could braze chromium.
BTW if my temperatures are wrong, I apologise, they are from hazy recollections of more than 30 years ago when I was taught, however I've just finished doing some copper pipework this morning (Yorkshire fittings, so solder with a brazing torch) so at least I know HOW to do it if not bthe absolute physics :lol:
I think the question has to be, what are you trying to join?
Scrit
WonderWoman
28 Jun 2005
South UK
Dont know what they are called but a picture is put between 2 microscope glass slides then metal is put round it to make it into a pendant.
I have a soldering thingy and did a bit in college.
I think Id prefer chrome colour but Ij ust wondered if brass was available as the flux is always chrome colour may look odd on brass.
Scrit
17 Sep 2002
Sounds more like the lead or pewter that is used in decorative leaded glass. Polished pewter is bright silver (like chromium, but not as glossy), but having a high lead content it will solder readily and cuts fairly easily. Have you tried looking bat any of the stained glass forums like Stained Glass Town Square (http://stainedglasstownsquare.com/) or the Creative Glass Guild?
Scrit
ike
24 May 2004
My sister does stained glass. She uses a copper foil ribbon for making similar to what you describe. She makes small painted glass panes for bespoke Christmas cards.
Stained Glass supplier should stock such items - copper/black finish and copper/silver finish also available.
Try here
WonderWoman
28 Jun 2005
South UK
How cool ,they do little 5x5cm pieces of cool glass types.
I contacted a couple of places for about 12 little squares of perspex, they both cam back with a charge of around £40!!
WoodPecker
30 Sep 2005
Leitrim, IRL
You can roughly cut out perspex with a saw and then file the edges square, it would be a lot cheaper.
WonderWoman
28 Jun 2005
South UK
Yep thanks
I found a hobby site that sells small a4 sheets of perspex for a couple of quid, I just need to know how much delivery is.As I have found sometimes dlivery charges make the final total sky rocket.They havnt got back to me yet:eek:(
I could borrow a jigsaw to cut bits or I have a hand saw.
WoodPecker
30 Sep 2005
Leitrim, IRL
Make sure the jigsaw has variable speed and cut at a slow speed. Aldi had a variable speed jigsaw (last week I think, might have some left) has variable speed,well made and very good value for £20.
Scrit
17 Sep 2002
WW
Another potential source of Perspex (acrylic) offcuts is the local sign maker. They may have some coloured offcuts to cadge for free, probably mainly in opaque colours, but you never know
Scrit
frank
10 Sep 2003
cheshire
wonder woman if you go in your costume you will get it for free :wink: :wink: :D
frank
WonderWoman
28 Jun 2005
South UK
I used to have on but gave it to a charity, love the idea of someone in another country dressed as Wonderwoman, hope it cheers them up.
