Back in October I took the plunge and had a go at turning, but although I've enjoyed it I've found that I don't really use it as much as I thought I would.
As some of you may have read in the thread over in General Woodworking, I'm having a clear out to fund a new tablesaw, so I'm being brutal and putting all my gear up for sale.
All in good working order, and all about 4 months old. Starting with the lathe itself:
As you can see - space here is pretty tight! This photo has the headstock slid right along the bed.
Specs for the lathe can be found here:
http://www.axminster.co.uk/product-Axminster-AWVSL1000-Woodturning-Lathe-780615.htm
Next up, the chuck (an Axminster K10 with C type dovetail Jaws), various gubbins that came with the lathe and my el-cheapo grinder with homemade sharpening jig (if you don't want this then it'll go in the bin!)
Finally, some tools:
All crown:
* 3/8ths Spindle Gouge
* 3/4 Roughing Gouge
* 1/4 Parting Tool
* 3/4 Flat Skew
* 1/2 Bowl Gouge
Basically everything you need to get started in turning, 4 months old and hardly used.
Unless I don't get any response, I'd like to sell everything in one go, so I'd like to see £330 for this little lot.
Local pickup from Farnborugh only I'm afraid as it's pretty heavy.
-Tom
All crown:
* 1/4 Parting Tool
* 3/4 Flat Skew
* 1/2 Bowl Gouge
-Tom
