stevebuk
hi guys
first time tonight to get to grips with th hegner, i have removed the lower clamp cover for ease of use but fitting a blade into the clamp is for me a nightmare, i cant seem to get the blade straight and the screw only fit in one way (is that right). I took out the clamp that came fitted with the blade and looked at it to see if i could match it, but the blade either moves off centre or if i put the screw in from the other side it just bends the blade, i cant believe £800 of scrollsaw and it has ***** clamps like this (just ranting)..
your help would be apprciated..
thank you
thank you
