JasonOwen
Hi,
Im afer a lathe to finish Snooker cues on.
Not sure if I will be able to find something suitable without going to industrial standards.
Heres what I would require..
Between centres maximum 60 inches
Head stock bore of minimum 32mm
Single phase as it would live in the garage/workshop
It will be used for -
Final sanding of snooker cues along the bed.
Putting most of the cue through the head stock bore to make a small tenon to fit the ferrule
Boring into the butt to fit joints
Any clues?
I did hear Record Lathes can be easily extended due the bed bars?
Appreciate any help.
The length of bed isnt the be all and end all as with a large head stock bore I could work the cue in 2 halves.
Any clues?
