I see forom the compo for turned work that theres a number of turners on here
Ive managed to convince a family member to get me one for Xmas.
Ive a small lathe- Axminster perform cc somethings. The yellow one that came out about 8 years ago with the extension bed.
All in all its been a good tool, and ive used it for a number of bowls inc a couple of nice time spend ones, some bed posts, and with the extension fitted a pair of meter long tapering columns for a reproduction fireplace(that was fun)
But i was always stuck for mounting work. Faceplate mounted for the outside with screws then paper and glue to enable the inside to be hollowed out. But as you all no doubt know its likely to be offcenter
So ive finally gotten around to getting one and someone else has to buy it :lol:
This is the choice - The Record Power RP2000 compact scroll chuck
http://www.recordpower.co.uk/product/co ... tpi-thread
I really cant believe its so small- 62mm diameter. I actually cant believe its so cheap
Anyone got one ? and can offer some advice.
Like how secure does it hold. Obviously i dont see it being tightened up on work as you would with a nut and bolt which i guess would crack or break it so what stops it from loosening off while in use ? Is the scrolling action stiff or does it naturally just hold tight at hand tightness.
What about the Nova G3 ?
