maverick54
Hi guys is there an electrical device that can be fitted, to slow a mini lathe with a minimum RPM of 700 down to around 350 - 400rpm
Robbo3":1scn59b2 said:Perhaps it would be better to say why you need to slow the lathe down rather than ask if it's possible.
There was another thread on this subject only a few weeks back
- slowing-a-lathe-down-t66914.html
shaver01":3lbpgttx said:If you have the DIY ability, one of the cheapest ways to slow a mini lathe is to use a industrial sewing machine 1/2hp clutch motor. It usually has to be built into a bench set-up so stops the lathe being easily transportable. Could be done for less than £50 with a used motor, just over £100 new, and would be foot operated. I have seen one set up and it works great.
Not an original idea, it was written about in one of the late Bill Jones books, but as said I have seen one and works fine. Fitted to a Axminster 330 lathe. The guy's disabled and uses it while seated.
