Aggrajag
I think the title gives it all away but of course I'll elaborate. I'm making really simple 3" boat shaped stands, out of cheap pine, for a glass project. They need a rebate from the centre of the back to about 1" from the front. The sides of the boat aren't perpendicular so I'm having to do these before I cut the boat shape.
I have a cheap, let's be frank it's utter dung, Dremel 3000 coupled with both their even more appalling router table and drill press. The table sort of works but as I'm not cutting the full length of the boat I'm having start/stop wandering issues where I enter or leave the front middle of the boat, which is upside down so I'm also guessing the start/end point, plus the table is so bad it's not really suitable. I could persevere, but I don't want to, I need to make loads of these.
I've tried using the same "3mm multipurpose spiral cutting bit" in my "proper" bench drill whacked up to full speed but I still have wandering issues where it's affected by the rotation of the bit, and aside from that I don't have a proper table guide. I clamped some wood on but as every boat pattern is in a slightly different location on each piece of wood the endless adjustment of the wood quickly became tiresome.
I have a real 1/4"-1/2" router table but I don't have any 3mm bits that fit. Searching the forums and google I hear about cutter bits but I can't establish if these go on router tables or on dedicated machinery.
So what's the best way of doing a 2" long, 3mm wide rebate on a 3" piece of wood?
Any advice seriously appreciated. Thank you.
