I've got my first TS - a SIP 01321 from ebay. So far, I've found the blade didn't go to 90 degrees (fixed), the fence extrusion is bent (turned it through 90 degrees to fix that, which cuts down the rip width a bit), and that 10" 16mm bore blades are few and far between. The fence itself has a bit of give in, and he mitre rail is a little narrower than the mitre slot, so it has a bit of give in it - I think another reviewer mentioned that. I'm working on a sled as suggested to me by jyates.
Overall the saw feels functional but very basic and tricky to adjust. Already regretting not spending a little more, and I haven't even used it much yet... I have a nice SCMS and router and they've spoilt me...
My final problem is how to square the blade with the fence. It's nearly 2mm out, and I can't see from looking underneath how to adjust it. The manual is as much use as a chocolate teapot....
Any hints?
Any hints?
