wcndave
I am putting my upstands in my utility room, and have a plastered concrete wall around the back.
I do the bead, spray some soapy water on, then use one of those plastic scrapers to create the seal.
When doing the corner where the laminate joins, it's easy, the rubber scraper works great, however where it meets the wall, it simply smears onto the plaster.
Any ideas for preventing this, and for removing it once you get this mess?
I was thinking of some blue tape on the wall, however as the wall is a bit textured, i think it will spread behind it anyway.
