Roxie
What do you use to clean the tile and grouting in a shower enclosure? The grouting is beginning to go a light brown.
Thank you for replying.
morturn":18uksfpf said:Not a good idea to mix bleach and acid, it produces toxic gases called chloramines are produced. It can also produce chlorine gas.
RogerS":bp9kq1o1 said:Don't whatever you do try bleach to clean the grout on marble tiles.
ColeyS1":2prsb5y6 said:This is the stuff you need
Usually £5-£6 a bottle. Sorts on mouldy silicone aswell. Does leave the room smelling quite bleachy for a few hours. I lent mine to someone was all but ready to regrout his bathroom. Hes a bit of a fuss pot but even he was amazed by the results.
Sent from my SM-G960F using Tapatalk
Interesting. Greece, being the land of marble, has marble monuments all over the place. Gravestones, war memorials, even window sills are marble. It's everywhere. When you want to clean it, you buy a bottle of strong hydrochloric acid from the supermarket (ask for marble cleaner) and spray liberally. Quite an exciting reaction follows - lots of fizzing, and then your marble looks brand new. I don't know if they do this with the Parthenon - you would think not...Eric The Viking":2xckinuj said:[
But marble and acid - no way!
Rorschach":hntlvej0 said:ColeyS1":hntlvej0 said:This is the stuff you need
Don't waste your money on this, it's just bleach on a fancy bottle.
Marineboy":3da6w82d said:My experience is that this stuff works much better than bleach and is worth the extra.
Rorschach":lu52fsm0 said:ColeyS1":lu52fsm0 said:This is the stuff you need
Register today and take advantage of membership benefits.
